Free Download Wondershare PDFelement Professional 12.1.11.4032 Multilingual + Portable Fast Links | 216.5/175.2 MbThe PDF Experience, Simplified. The easiest way to create, edit, convert and sign PDF documents. Get control over PDFs like never before. The most Powerful and Simple PDF solution that changes the way you work with your important documents forever.
Edit PDF Like Word
Wondershare PDFelement enables you to edit PDF documents just as easily as you would in Word documents.
Edit PDF Text
Add, edit, remove text, link, watermark, header&footer, or bates numbers on your PDF easily. You can also edit the size, font, and color of the added content.
When you need to change the background of the PDF file, you can also add or change the file's background with any color, PDF or image.
Edit PDF Image
Click on an image, then move, rotate, crop (resize), extract, replace, overturn or delete images in PDF. Even you can set the Z-Order of the image.
Export each image in a PDF to a separate image file with "Convert" feature of Batch Process tool.
Move and Align Objects
It is easy to move an item forward or back just one level, or send it to the front or back of the stacking order of elements on the page.
The Align properties options (in the right-hand panel on Windows version, or right-click to call up the Align properties) let you precisely align multiple objects on a side - left, right, top, bottom vertical center, and horizontal center.
Edit PDF Pages
Organizing pages in PDFelement is intuitively simple and fast. It is easy to sort, add, rotate, move, split, crop and delete PDF pages with PDFelement in a second, from anywhere.
Edit PDF Forms
PDFelement can help you create, edit PDF forms easily, also turn PDFs into fillable forms with "Recognize Form" tool or just add, delete, and drag and drop form fields or enable fields for e-signatures.
You can even add calculations and data validation rules to your form. It is simple!
Edit Scanned PDF
When you open a scanned document for editing, you need to perform OCR feature(optical character recognition) on PDFelement.
It can recognize text and characters from PDF scanned documents (including multipage files), photographs or digital camera captured images, so to make the PDF documents editable and searchable.
Edit Password Protected PDF
Unlock the PDF by entering the correct password so to access the file. Then you can edit, print, copy, comment, sign, organize the PDF file.
You can also remove security from a PDF if you have the document password.
Your Complete PDF Convert Solution
Convert PDFs into secure file formats, like Microsoft Office, image, text etc. in high-quality and minimum effort.
PDF to Word
Batch-convert PDF files to Word documents without losing fonts and formats. It supports .docx, .doc.
PDF to Excel
Convert PDFs to Microsoft Excel files: xlsx, xls, XML.
PDF to PPT
Convert PDFs to Microsoft PowerPoint files: .pptx, .ppt.
PDF to Image
Convert PDFs as separate images or into one single image with any image quality you want. It supports JPG, PNG, BMP, GIF, and TIFF.
System Requirements:Windows 11 and below
A computer with an Intel® Pentium® 4, higher, or equivalent processor
512 MB of memory (RAM), 1 GB recommended
1.5GB of free hard disk space for application files
Home Page -https://pdf.wondershare.com/
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorbn8c9.PDFelement.Pro.12.1.11.4032.Portable.rar.htmlbn8c9.PDFelement.Professional.12.1.11.4032.rar.htmlDDownloadbn8c9.PDFelement.Pro.12.1.11.4032.Portable.rarbn8c9.PDFelement.Professional.12.1.11.4032.rarFreeDLbn8c9.PDFelement.Pro.12.1.11.4032.Portable.rar.htmlbn8c9.PDFelement.Professional.12.1.11.4032.rar.htmlhttps://turbobit.net/3e1dr8vdyrt2/bn8c9.PDFelement.Pro.12.1.11.4032.Portable.rar.htmlhttps://turbobit.net/jqwpyk7kbfoy/bn8c9.PDFelement.Professional.12.1.11.4032.rar.htmlLinks are Interchangeable - No Password - Single Extraction
