05 de Abril de 2026, 21:51 *
Autor Tema: SAPIEN PrimalXML 2026 v4.7.87 (x64)  (Leído 13 veces)
« : 12 de Febrero de 2026, 22:14 »
Free Download SAPIEN PrimalXML 2026 v4.7.87 (x64) | 47 Mb
Working with XML as text can be tricky, tedious, and difficult. Why not use a tool that is specifically designed to edit, manipulate, and create XML files? PrimalXML is just that tool. Need to take a quick look at some XML data? Maybe you have to modify the structure of an XML file for another department. PrimalXML is here to help. Open any XML file and view it as text or in an element tree. Syntax coloring for elements and attributes makes everything clear. Apply styleSheets to the XML data and view the results in HTML. Validate the XML against a schema.
Provides XML PrimalSense code completion.
Automatically color your XML files for easy editing.
Validate XML files using a Schema file.
Apply style sheets and view the HTML results.
Explore and edit the XML using the Element Viewer.
Auto-format your XML files.
Fast element navigation and manipulation.
Copy and Paste XML objects intelligently.
Find and Replace XML objects.
Windows Server 2019/2022/2025 or Windows 10/11, 64-bit and ARM64 versions supported
20 MB free disk space
2 GB RAM
Visual Studio 2015-2022 Runtime
https://www.sapien.com/
vq861.SAPIEN.PrimalXML.2026.v4.7.87.x64.rar.html
https://turbobit.net/mwi6xbjqetb2/vq861.SAPIEN.PrimalXML.2026.v4.7.87.x64.rar.html
