Free Download Formware 3D Slicer 1.3.0.8 (x64) | 77 MbPowerful 3D Printing slice and support generation software. 3D Print job preparation can be a time consuming task. Orienting, supporting and slicing your build jobs in a way that they actually print can be challenging.
FeaturesPremium Support generation and editting
AUTOMATIC GENERATION
The fastest way to support generation for your prints. Automatic.
100% DRAGGABLE SUPPORTS
Just drag supports and the geometry adapts automatically.
POINT/LINE MODE
Edit supports more easily in point/line mode.
ADVANCED EDGE & SURFACE EDITS
Edit/resample/delete critical detected surfaces or edges.
Quick Mesh editting
MESH HOLLOWING
Hollow your mesh to save printing material and create a light weight structure.
LATTICE INFILLS
Add perfect lattice infills to get a strong part.
DRAINAGE HOLES
Add holes to your hollow parts to lets material flow out easily during printing
MIRRORING & SCALING
Easily mirror/scale your supported part including supports. Saving you time.
Easy User interface
3D Dlp printer support generation slicer
OBJECT MANIPULATOR
Easily move/rotate/scale your objects with the click and drag manipulator.
COPYING
Array copy objects to build an entire table with a few clicks.
IMPORT & EXPORT
Import and export .stl, .slc, .obj, .ply, .amf and project files to save all your work.
SHORTCUTS & MORE
Formware 3D includes an extensive list of keyboard shortcuts to save you time.
Supported printers
Designed for resin and inkjet 3d printers.
Used with the following machines:
Generic LCD/DLP machines
Kudo 3d (slice export)
Wanhao D7/D7 Plus (.cws export + printcontroller)
Wanhao D8
Anycubic photon (.photon)
Anycubic photonS (.photons/.pws)
Phrozen Shuffle & Shuffle XL
Elegoo Mars (.cbddlp export)
Epax X1/X10 (.cbddlp export)
NanoDLP machines (connect with IP address, upload: .stl, .slc or .png)
Peopoly Moai/SLA (slice as .gcode)
Home Page -https://www.formware.co/slicer
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorxf1rv.Formware.3D.Slicer.1.3.0.8.x64.rar.htmlDDownloadxf1rv.Formware.3D.Slicer.1.3.0.8.x64.rarFreeDLxf1rv.Formware.3D.Slicer.1.3.0.8.x64.rar.htmlhttps://turbobit.net/2y0uz26fl0cx/xf1rv.Formware.3D.Slicer.1.3.0.8.x64.rar.htmlLinks are Interchangeable - No Password - Single Extraction
