05 de Abril de 2026, 00:27 *
Autor Tema: BETA-CAE Systems 25.1.4 Win x64 English  (Leído 22 veces)
Conectado Conectado
« : 23 de Febrero de 2026, 12:12 »
Free Download BETA-CAE Systems 25.1.4 | 2.2 Gb
BETA is now part of Cadence announces the release of the[ b]25.1.4[/b] for ANSA, EPILYSIS, META, KOMVOS, SPDRM, ANSERS and FATIQ, with critical bug fixes and selected implementations.
What's new in BETA CAE Systems 25.1.4
Known issues resolved in ANSA
GUI
- Screen display would fluctuate in delay upon mouse click, while space mouse was active.
CAD Import / Export
- Several issues would be encountered upon translation of CATIA V4 models.
Modular Run Management
- External connectors would disappear when replacing a simulation model from DM in a simulation run.
Data Management-
- When importing a Library Item and a PrePostUploadMainFileScriptFunction was set in ANSA.defaults file, the ANSA_BATCH license would not be released, unless exiting ANSA.
Shell Meshing
- ANSA would terminate unexpectedly when running check for Solid Cracks.
- ANSA would exit abnormally, in case of applying "Grids > Align" function to target Descriptionel entities.
Volume Meshing
- Manual execution of the Volume Mesh function multiple times would lead to ANSA termination.
- Focusing on Structured Meshing, MAP window did not behave consistently after pressing "Back" to deselect entities.
LS-DYNA
- Unexpected termination would occur when reading *PARAMETER_LOCAL entries and the Include ✅File Name containing the parameter was too long.
- Moreover, partially encrypted materials would be erroneously output.
Abaqus
- ANSA would cease operating when Contact entities used in the respective assistant were defined on Properties with long names.
Optistruct
- ANSA would exit abnormally when copying PTFORCES using the Transform function.
Known issues resolved in META
GUI
- Syncing windows were not operating smoothly along with space mouse navigation actions.
LS-DYNA
- Abrupt software termination would occur when time history results were to be read and abstat_cpm results were included in the same directory.
- Geometry was not read properly when the DEFINE_TRANSFORMATION keyword was used.
- In addition, D3ZCF files were not input correctly.
Pam-Crash
- Reading Pam-Crash results from files compressed with FEMZIP version 16.28 would occasionally lead to abnormal termination, when SELOUT was involved.
Abaqus
- Unexpected termination would occur upon reading results on integration points.
- Centroid value was incorrectly computed when scalar results for CPE8 elements were read using the IntPnt option.
- Reading results using the "Layer" option did not work properly.
Ansys
- ANSA would cease operating when deformation was loaded using displacements values, stored in single-precision format.
Moldex3D
- Results from Moldex3D 2025R could not be successfully read.
FEMZIP
- META would terminate unexpectedly when loading an ERF file compressed with FEMZIP version 16.28.
Optistruct
- Wrong result values were read from Optistruct .pch files for TRIA elements.
BETA CAE Systemsis an engineering software company committed to the development of best-in-class CAE software systems that meet the requirements of all simulation disciplines. Amongst the company's products, the ANSA pre-processor and the µETA post-processor, hold a worldwide leading position, in many sectors, including the automotive, railway vehicles, aerospace, motorsports, chemical processes engineering, energy, electronics, heavy machinery, power tools, and biomedical.
ANSAis an advanced multidisciplinary CAE pre-processing tool that provides all the required functionality for full-model build up, from CAD data to ready-to-run solver input file, in a single integrated environment. ANSA is the users' preference due to its wide range of features and tools that meet their needs. The list of productive and versatile features is long and the alternative tasks and processes to be completed using them are countless.
METAis a thriving multi-purpose post-processor that meets the diverce needs of various CAE disciplines for processing solver results until a complete reporting. It owes its success to its impressive performance, innovative features and capabilities of interaction between animations, Descriptions, videos, reports and other objects. Offered in a package with ANSA or as a single product, META with its high performance and level of automation and customization, eliminates the need for use of any other post processing tool. Porting product data and meta-data from diverse CAD systems to CAE pre-processing is a challenging task that requires advanced and configurable tools.
CAD to ANSA Translatorsprovide an advanced solution to efficiently translate CAD data to ANSA format. The translators make it possible to access geometry and meta data (part number, material, gage, part location in assembly, etc.) from the CAD files. The translators can either be setup to run as a stand alone batch operation from the command line, or for a large number of jobs can be driven through the provided GUI to manage the settings and monitor the translation progress.
Cadenceis a pivotal leader in electronic systems design, building upon more than 30 years of computational software expertise. For 10 years in a row, Fortune magazine has named Cadence one of the 100 Best Companies to Work For.
Cadence Design Systems, Inc.announced it has completed its previously announced acquisition of BETA CAE Systems International AG, a leading provider of multi-domain, engineering simulation solutions. BETA CAE accelerates Cadence's Intelligent System Design strategy by expanding its multiphysics system analysis suite with highly complementary products, enabling Cadence to offer a more comprehensive portfolio to its customers.BETA CAEhas a very strong footprint in the automotive vertical sector and at leading companies in the aerospace, industrial and healthcare industries.
Owner:BETA CAE Systems Inc.
Product Name:BETA CAE Simulation Solutions
Version:25.1.4
Supported Architectures:x64
Website Home Page :www.beta-cae.com
Languages Supported:english
System Requirements:Windows *
http://peeplink.in/01ab94821f47
ac09s.BETA-CAE-Systems-25-1-4.rar
ac09s.BETA-CAE-Systems-25-1-4.rar.html
https://turbobit.net/l5bly1nnuk4b/ac09s.BETA-CAE-Systems-25-1-4.rar.html
