04 de Abril de 2026, 19:57 *
Autor Tema: Albus Bit AD FastReporter Pro 26.2.20  (Leído 30 veces)
« : 24 de Febrero de 2026, 19:23 »
Free Download Albus Bit AD FastReporter Pro 26.2.20 | 15.4 Mb
AD FastReporter makes generating, storing, scheduling, and sharing AD reports easier and faster, so you can focus on more important tasks.
Get your report in three easy steps:
- Search or browse to find the report form you need.
- Customize report fields.
- Press 'Generate' and sit back while the AD FastReporter creates the report.
Customize Your Reports
With our Pro version, you can create your own customized report forms to meet your specific reporting needs.
The built-in filter manager will help you quickly and easily create even complicated report filters using AND/OR conditions and criteria grouping.
Export Reports
AD FastReporter Pro lets you export reports in seven formats, including CSV, Excel, PDF, XML, ODS, JSON, and HTML.
Report Storage
AD FastReporter's built-in local database and engine automatically store your custom report forms and generated reports for secure and hassle-free report storage. You can easily turn off this feature if you prefer.
Automate Report Generation
AD FastReporter Pro automates report generation and distribution with customizable tasks, including connection, report form, export options, and email options. With a task ID, you can perform tasks via the Windows command line, saving time and streamlining the report process.
Custom Fields
AD FastReporter 2023 allows you to add custom fields to your reports beyond the standard fields available in the tool. It's a simple process of specifying the field's name, description, LDAP attribute, and field type, and choosing which report categories the field will be available in. This enables you to create custom reports with all the necessary information.
Calculated Attributes
AD FastReporter 2023 has unique calculated attributes not found in other tools or PowerShell commands, enabling quick report generation with specific information. It provides a full list of built-in fields for easy access to relevant fields.
Fast and Efficient
AD FastReporter 2023: fast, reliable, and efficient reporting with unparalleled speed, even for large Active Directory object counts. Minimizing LDAP requests to domain controllers means generating reports in a fraction of the time compared to other tools, without sacrificing accuracy or quality.
Software Requirements:
Supports Windows OS Windows operating system starting from Windows 7 and above (including Windows 11 and Windows Server 2022).
Microsoft .NET Desktop Runtime 6 (LTS)
https://adfastreporter.com/index.html
colk6.Albus.Bit.AD.FastReporter.Pro.26.2.20.rar.html
https://turbobit.net/ytkh76iztiel/colk6.Albus.Bit.AD.FastReporter.Pro.26.2.20.rar.html
