Free Download MiniTool Partition Wizard 13.6 (x64) All Editions Multilingual Fast Links | 141.8 MbMiniTool Partition Wizard is a rich-featured partition magic, which is designed to optimize disk usage and to protect your data. It comes with so many powerful features with which you can completely control your hard disk and partition. With its user-friendly interface and straightforward guidance, you are able to resize partition, copy disk, scan lost partitions, and migrate OS to SSD easily and safely. Due to its outstanding performance, MiniTool Partition Wizard Free Edition has earned good reputation among global users.
Features:Extend System Partition
Extend system partition to solve low disk space issue by its "Move/Resize Partition" & "Extend Partition" f
Copy Disk Partition
Copy disk partition for hard drive upgrade or for data backup in case that your computer may run into a problem.
Merge Adjacent Partitions
Combine two adjacent partitions into a bigger one safely so as to make full use of the unused space.
Migrate OS to SSD
Migrate OS to SSD/HD to get better computer performance or to back up OS for system restoration.
Surface Test
Check disk/partition surface test to confirm whether there are bad sectors on the target location.
Basic Management
Enable to manage disk partitions such as create, delete, format, split, wipe, align partition and more.
Convert Disk Partition Table
Convert non-system disk from MBR to GPT and vice versa without data loss to support large drive or full OS.
Convert File System?
Convert NTFS to FAT or convert FAT to NTFS without formatting to support early Windows OS or to store large files.
Set Primary/Logical
Set partition logical to create more than four partitions or set partition primary to make it active.?
Home Page -https://www.partitionwizard.com
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorf553b.MiniTool.Partition.Wizard.13.6.x64.Multilingual.rar.htmlDDownloadf553b.MiniTool.Partition.Wizard.13.6.x64.Multilingual.rarFreeDLf553b.MiniTool.Partition.Wizard.13.6.x64.Multilingual.rar.htmlhttps://turbobit.net/yugtlwgofq8o/f553b.MiniTool.Partition.Wizard.13.6.x64.Multilingual.rar.htmlLinks are Interchangeable - No Password - Single Extraction
