04 de Abril de 2026, 15:41 *
Autor Tema: ConceptDraw MINDMAP 15.1.1.296 + Portable  (Leído 45 veces)
« : 24 de Febrero de 2026, 19:25 »
Free Download ConceptDraw MINDMAP 15.1.1.296 + Portable Fast Links | 132 / 109 Mb
ConceptDraw MINDMAP 15, a leading mind mapping software tool includes a comprehensive set of solutions for designing and building timesaving mind maps. Create mind maps that intuitively illustrate your thought process. Organize ideas and data with a comprehensive productivity tool that is flexible and easy-to-use. Generate a great assortment of document styles and formats.
Mind Mapping for Project Management
ConceptDraw MINDMAP 15 is a perfect tool when it comes to project planning. You can create mind maps that contain branches with project parameters: Duration, dates, percent completed, executors, etc. Any topic in your mind map can be transformed into a project task. Any mind map can be transformed into a project map. Turn the mind map into an organizer for your projects - the Map Minder panel tracks real-time project progress data in your project mind maps and displays the number of unstarted tasks.
Intelligent Topics
A mind map can be turned into an electronic file cabinet by adding attachments in any file format. Keeping all information for a project or process one click away makes embedded files a productivity booster.
Hyperlinks and Text Notes
Extend any mind map topic by using Hypernote. It is the blend of a text note with multiple hyperlinks. Mind maps with Hypernotes can easily support an impressive amount of knowledge in a single map. Everything is at your fingertips.
Splendid Appearance
More than 20 built-in styled themes, plus the ability to design custom themes makes ConceptDraw MINDMAP 15 an impressive visual tool. Quickly make a mind map template for organization meeting schedules and reporting. Create mind maps that stand out from the crowd. With ConceptDraw MINDMAP 15 it easy to incorporate graphic images into your maps, making maps even more impactful. Images add a blend of creativity and functionality and provide your mind map with a distinctive look. Images can be either attached to a topic or added inside of the topic, or as floating images that can be moved freely. You can use pre-designed images from graphic libraries delivered with ConceptDraw Solutions or your own image from a file. You can also import images from ConceptDraw DIAGRAM custom libraries.
Mind Map Presentation
ConceptDraw MINDMAP 15 provides a set of tools to quickly create a slideshow. Using MINDMAP editing tools there is no faster way to build a presentation. Intuitive features allow for the selection of mind map areas that are to be included in each slide. Then drag-and-drop views to sequence slides. When slide sequencing is completed it is then easy to quickly transition to presentation preview mode. The resulting slide presentation can be exported to MS PowerPoint to share with the team or the world.
Data Exchange
ConceptDraw MINDMAP 15 breaks boundaries in mind mapping data exchange for project managers and mind mappers. It offers the ability to exchange data with Microsoft Project, Microsoft Office, ConceptDraw PROJECT 14, MindManager, XMind, and FreeMind. MINDMAP 15 also provides the ability of export to ConceptDraw DIAGRAM 17 files format.
ConceptDraw OFFICE Integration
ConceptDraw MINDMAP 15 can identify and structures ideas; as well as generate final documents and presentations. Open a mind map in ConceptDraw PROJECT 14 to assign tasks and report completeness of multiple projects. Use export to ConceptDraw DIAGRAM 17 to build project diagrams, organizational charts, SWOT matrices,, and more from your mind map's structured data. The ConceptDraw OFFICE 10 products provide a set of tools that support any professional activity. Choose the proper tools for your business to get the best results. Your data easily integrates with the other ConceptDraw OFFICE 10 applications because of our innovative INGYRE technology.
What is New in ConceptDraw MINDMAP 15
The new ConceptDraw MINDMAP 15 includes a set of improvements tailored to the needs of our users. We are grateful to active MINDMAP users for the ideas that we use to improve MINDMAP. ConceptDraw MINDMAP 15 for macOS has been successfully adapted to Apple Silicon and is compatible with the latest macOS 14 Sonoma. The new release makes mind map creation clearer and more accurate on both macOS and Windows platforms. Find below a list of improvements that enable you to be more productive with MINDMAP 15 both on macOS and Windows platforms. When designing your next mind maps, give them a try and see how much time and effort you can save.
Outline View
View and edit your mind map as a diagram with an updated interface and new editing capabilities.
Mind Map Sharing
More social networks for one-click publishing of your mind maps.
Mind Map Boundaries
Boundary's interface has been updated with a new control panel and new shapes to help you visually summarize your thoughts. If you want to summarize some of the ideas presented in your mind map, new boundary shapes are the best way to do that. The new side panel will help with boundaries formatting.
System Requirements
- Microsoft Windows® 8.1, 10, 11 (64-bit)
- CPU: Intel or AMD; 1.8 GHz or higher
- RAM: minimum 4 GB
- HDD: minimum 1.5 GB disk space
https://www.conceptdraw.com/products/mind-map-software/
stq12.ConceptDraw.MINDMAP.15.1.1.296.Port.rar.html
stq12.ConceptDraw.MINDMAP.15.1.1.296.rar.html
https://turbobit.net/bqb0dv5ua4w0/stq12.ConceptDraw.MINDMAP.15.1.1.296.Port.rar.html
https://turbobit.net/6zjeplz87qyf/stq12.ConceptDraw.MINDMAP.15.1.1.296.rar.html
