06 de Abril de 2026, 10:54 *
Autor Tema: DxO PureRAW 5.8.0.14 Multilingual Portable (x64)  (Leído 44 veces)
« : 28 de Febrero de 2026, 14:25 »
Free Download DxO PureRAW 5.8.0.14 (x64) Multilingual Portable Fast Links | 274.6 Mb
Pure, flawless, noise-free RAW photos. Revolutionize your image quality without disrupting your existing Lightroom® or Photoshop® workflow. Dramatically improve image quality, whatever you shoot. Discover 12 reasons why DxO PureRAW2 will deliver significant improvements to your images.
Why you should use DxO PureRAW2
Whatever your genre, DxO PureRAW2 will transform the quality of your RAW files.
Wildlife
You don't need the best telephoto lens on the market to get incredible results. DxO PureRAW2 cleans up your RAW files, giving you greater flexibility when using faster shutter speeds, and allowing you to shoot earlier in the morning or later into the evening.
Landscape photography
Get the maximum detail from your gear thanks to DxO's renowned lens and camera profiles, automatically correcting any distortion, vignetting, and chromatic aberrations. You can have more freedom to shoot without a tripod as faster shutter speeds with higher ISO levels are now less of a problem.
High-ISO photography
With DxO PureRAW2, you can get an extra two stops of ISO thanks to its power to clean up noise from your RAW files. Instead of worrying about image quality and lowering your shutter speed, keep shooting.
Natural light portraits
Creamy bokeh and out of focus areas often have a tendency to become messy with noise. With DxO PureRAW2, they stay velvety smooth and free of artifacts.
Resurrect old RAW files
Breathe new life into RAW files shot on older cameras. The photos in your archive you thought were not good enough because of a lot of noise or a soft lens - these images can be transformed.
Wide-angle lens photography
Automatically correct lens distortions, vignetting, and chromatic aberrations and make your wide-angle photography cleaner and sharper.
High resolution, high detail
Your lenses deserve the best corrections. With DxO PureRAW2, you get access to DxO's widely acclaimed lens and camera modules based on more than fifteen years of rigorous lab testing. In addition, DxO PureRAW2 will allow you to draw out more detail from the shadows without introducing noise.
Long exposures
Open your shutter for longer without having to worry about the smooth areas of your photos becoming polluted by noise.
Astrophotography
Thanks to machine learning, DxO PureRAW2 knows that it should remove noise without making stars and constellations disappear. Stars will be crisper and more defined, and DxO's Optics Modules means that the corners will be sharper and free of vignetting.
Live music
Often regarded as one of the noisiest genres of photography, live music can be a struggle when trying to balance ISO and shutter speed. Gain an extra couple of stops of flexibility thanks to DxO PureRAW's ability to eliminate noise without losing detail.
Drone photography
Smaller sensors can be problematic, especially when shooting in low light or high contrast situations. With DxO PureRAW2, lenses are automatically corrected to improve detail and sharpness, and shadows remain refreshingly free of noise, even when ISO is increased.
Street photography
Shooting at small apertures in the day or on dimly lit streets at night, street photographers gain extra freedom thanks to the option to push your ISO a little higher. You can also draw more detail out of the shadows as a result of processing your RAW files through DxO PureRAW2.
RAW
CR3, ARW, NEF, RAF, DNG, and many more.
DxO DeepPRIME
Demosaicing and denoising.
DxO Optics Modules
Improvements to sharpness. Corrections to distortions, vignetting, and aberrations.
Optimized
Linear DNG or JPEG.
Maximize the quality of your RAW files before editing them in Adobe Photoshop, Lightroom, or other RAW editing software thanks to DxO's exclusive demosaicing, denoising, and lens correction technology.
RAW processing
Demosaicing and denoising like you've never seen before
DxO PureRAW2 delivers exceptional image quality through its deep learning technology, DxO DeepPRIME. This update features optimized processing times and compared to the previous version, it is
- 4 times faster on an Apple Silicon Mac
- up to 1.5 times faster on the best Windows computers Noise reduction has never been this good.
The leading authority in lens corrections
Thanks to years of highly accurate tests in DxO's purpose-built laboratory, DxO PureRAW2 corrects every possible lens defect.
DxO PureRAW2 now supports Fujifilm X-Trans files
Delivering incomparable quality in terms of lens correction, demosaicing, and denoising, DxO technology is now available to Fujifilm X-Trans camera users.
Photo editing made simple - New in version 2
Choose from three integrations and enjoy a process that is free of sliders and complex adjustments. Convert your RAW files in just a few clicks, without disrupting your workflow.
HiDPI Support - New in version 2
HiDPI displays for Windows machines are now supported, offering greater comfort to photographers.
8,000 New Optics Modules - New in version 2
DxO has updated its Optics Modules with a raft of new cameras and lenses, including several Leica M lenses. DxO PureRAW2 now supports more than 70,000 lens and camera combinations.
- Intel Core® 2 or AMD Athlon™ 64 X2 or higher (Intel Core® i5 or higher recommended)
- 4 GB of RAM (8 GB recommended)
- 4 GB or more of available hard-disk space
- Microsoft® Windows® 10 version 1809 (64-bit) and above, Microsoft® Windows® 11
- GPU Compatibility starts from
- NVIDIA GeForce 8 Series, ATI Radeon HD2000 Series, and Intel HD Graphics 2000 Series.
- If no compatible card is available, GPU acceleration will be disabled, and the CPU will be used.
https://www.dxo.com/
http://peeplink.in/1f77cb29ca5c
mf84e.DxO.PureRAW.5.8.0.14.x64.Multilingual.Portable.zip
mf84e.DxO.PureRAW.5.8.0.14.x64.Multilingual.Portable.zip.html
AlfaFile
https://alfafile.net/file/Ad5gH/mf84e.DxO.PureRAW.5.8.0.14.x64.Multilingual.Portable.zip
https://turbobit.net/13dppjrided6/mf84e.DxO.PureRAW.5.8.0.14.x64.Multilingual.Portable.zip.html
FileServe
https://fileserve.com/87hhr2y512nu/mf84e.DxO.PureRAW.5.8.0.14.x64.Multilingual.Portable.zip.html
